georgewade's avatar
georgewade
WiFi network
Good evening all; I just successfully installed and registered my CM1150V modem router. I have internet and voice but I'm a little lost here as to connecting to WiFi. My pc has installed the device a...
  • RAXXXSTER's avatar
    May 22, 2020
    It’s not a router. No wireless functionality. Great modem, but don’t expect much help with proper installation from Comcast during COVID. I’ve tried absolutely everything using this modem with the new Orbi RBR850 router (part of model no. RBK853), and after trying everything with tech support, I can pretty confidently say that this tech is as advertised and, if properly installed, is superior.
    I’m running 850 download / 42 upload / 15 ping on the Orbi App from a distance of 20 feet from the router. It’s mind blowing, so don’t give up. If I see your post, I can answer a lot of questions, but first you need to get a suitable for this modem router.
    RAXXXSTER
    - CM1150V WiFi6 modem
    - ORBI RBK853 WiFi6 whole home mesh
    -3300 sq ft, 2-level, 50 yr old home
