floydniii
Jan 10, 2023Aspirant
WiFi not connecting to Android 12.0 TV converter box
Are the WiFi 6 (AX) routers compatible with the Android 12.0 H69 MAX Shenzhen TV box?
floydniii
Is the RAX120v2 router compatible with the Transpeed Android 12.0 TV box model H96 MAX V12? Can't connect the Transpeed to the router.
Reports the router is (Disabled). Thanks for the help.
DarrenM
Feb 21, 2023Sr. NETGEAR Moderator
You may want to try changing the router channel the android box may not like the wireless channel the router is set to.https://kb.netgear.com/25182/Resolving-poor-5GHz-wireless-range-signal-from-my-NETGEAR-router
