esebm
Jul 19, 2025Aspirant
WiFi Problem?
Hi, I have a Netgear AX1800 WiFi Router which seems to have a wifi problem. The wifi signal on my wife's laptop one floor above the router fluctuates from all bars down to zero within a minute. It u...
CrimpOn
Jul 19, 2025Guru - Experienced User
It is often helpful to know the actual product number from the label on the bottom of the router.
(AX1800 is a measure of 'speed'.)
Does this signal strength change appear on the laptop display itself or on a "WiFi app" that is being used to look at the WiFi?
