CaptainB
May 20, 2020Tutor
WiFi Scheduler not Working
RAX15 Router Firmware Version V1.0.1.56_2.0.20. Timezone is (GMT -1) Azores, Cape Verde Is. I am in the Eastern US timezone GMT -5. I set the timezone to minus one so that I can have the rout...
Christian_R
May 22, 2020NETGEAR Employee Retired
Hi CaptainB,
I would recommend getting in contact with our support team to assist with WiFi scheduling.
https://www.netgear.com/support/default.aspx
Christian
- CaptainBMay 23, 2020Tutor
I did. Their respose was : Please once downgrade the firmware to a step lower version.
After that didn't work they recommended doig a factory reset, which I did and that doesn't change anything either.
It did however show me two new problems:
1) Setting the Automatically Adjust for Daylight Savings time check box sets the GMT to -3 from -4 when the timezone is set to (GMT -4) Atlantic Time.
2) When the older firmware was installed, I went to Advanced->Adminstration->Router Update and selected
Check for new version from the internet which resulted in: No new firmware version available.
It also might be noted that IPV6 is much slower than IPV4, at least with Comcast Internet.
- Christian_RMay 27, 2020NETGEAR Employee Retired
Hi CaptainB,
Thanks for confirming. I would recommend that you continue to work with our support team. Please let me know if your case has been closed or has not been escalated and I'll notify support.
Christian
- CaptainBMay 27, 2020Tutor
Thanks, I would really like for a trouble ticket or some type of notification be issued to flag the problem that the WiFi scheduler does not work.
