mrn8tural
Aug 08, 2021Aspirant
WiFi works but ethernet stopped working
Configuration: M1 Macbook Air. Nighthawk router connected to Cisco cable modem (supplied by Cox Cable), connect to the computer - Router to Wavlink hub via ethernet; hub to computer via USB. Sin...
Aug 08, 2021Guru - Experienced User
I've seen issues with usb hubs causing issues.
do you have a different usb-ethernet adapter?
Or lightning--ethernet adapter?
mrn8tural
No, I don't have another hub. It's worked with this hub just fine for the past 2 months, until this afternoon.
I see there is a USB port on the front of the router. Could I just go from that to one of the USB ports on the hub? So far I was just using it to run the fan in the cooling pad I have my Mac sitting on.
- plemansAug 09, 2021Guru - Experienced User
No. You couldn't go usb===usb with the router to mac.
Could have been a drive update to the hub.
Do you have a cheap lightning/usb to ethernet adapter you could try?
That's what I'd be checking on.
Are ANY other wired devices having issues or just the hub?
