jvhaslup
Sep 30, 2020Star
Wifi6 Nighthawk Firmware update keeps failing
Hi all! Tried updating the available firmware update last night, and it failed multiple times. Looking for a solution that doesn't include resetting my router to factory defaults. R,...
- Sep 30, 2020
I wouldn't use the app. Its where we see the most issues with corrupt firmware. I'd recommen doing it over a hardwired connection.
Sep 30, 2020Guru - Experienced User
are you updating using the automatic update feature?
Or are you trying to manually update it? (I'd recommend doing it manually and doing it over a hardwired connection)
