Chris795
Jun 08, 2023Aspirant
WiFi/internet keeps dropping
Hi, My AX54200 (model # RAX43) router keeps dropping WiFi every few days, and all the connected devices will go offline. I tried resetting to factory settings and updating the firmware, but it still...
- Jul 12, 2023
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-modeTry option #2 first...
Chris795
Jun 11, 2023Aspirant
Thank you. I will give that a try first and see how it goes.
Jun 11, 2023Guru - Experienced User
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
- Chris795Jul 12, 2023Aspirant
Apologies for the delay.
I tried the suggestion to turn off the ISP modem, Netgear router, disconnect all devices, and restart everything. However the issue persists.
Firmware version is v1.0.12.120 (router says latest version is installed).
The ISP modem is a Home Hub 3000.
Channels were set to auto. I switched as suggested, however the issue happened again a day or two later.
Regarding neighbour WiFi, yes there are lots. I can see 30 or more, depending on what device I'm using.
Thanks!
- FURRYe38Jul 12, 2023Guru - Experienced User
Couple of options,
