ggivens
Aug 02, 2020Aspirant
Will the Nighthawk AX8 8-Stream Modem/Router work on the TDS Network?
I want to purchase a new Nighthawk AX8 8-Stream WiFi 6 cable Modem/Router to replace my service provides's modem/router. I have checked with TDS which is my service provider and I can't find a clear ...
ggivens
I just wanted to add, that my TDS setup for service entering my home is coming from TDS's fiber optical cable into a box and from there they ran a ethernet cable to the modem/router that they provided. I noticed that the Nighthawk AX8 has a WAN port so that's why I'm trying to find out if it will work with the TDS network.
- Christian_RAug 06, 2020NETGEAR Employee Retired
Hi ggivens,
We have not received any feedback that the RAX80 is not compatible with TDS.
Christian
- ggivensAug 07, 2020Aspirant
Christian,
Thanks for responding, but what I really need to know if you know of anyone that is using it with TDS's fiber opital portion of their network. I have fiber coming to my home and from there they are running ethernet cable to the modem/router's WAN connection. I noticed that the AX8 has a WAN port, is that only for bridging or can it be setup for a direct connect to their network?
