ggivens
Aug 02, 2020Aspirant
Will the Nighthawk AX8 8-Stream Modem/Router work on the TDS Network?
I want to purchase a new Nighthawk AX8 8-Stream WiFi 6 cable Modem/Router to replace my service provides's modem/router. I have checked with TDS which is my service provider and I can't find a clear ...
Christian_R
Aug 06, 2020NETGEAR Employee Retired
Hi ggivens,
We have not received any feedback that the RAX80 is not compatible with TDS.
Christian
ggivens
Aug 07, 2020Aspirant
Christian,
Thanks for responding, but what I really need to know if you know of anyone that is using it with TDS's fiber opital portion of their network. I have fiber coming to my home and from there they are running ethernet cable to the modem/router's WAN connection. I noticed that the AX8 has a WAN port, is that only for bridging or can it be setup for a direct connect to their network?
