jstro
Jun 24, 2025Aspirant
Windows computers won't connect to WIFI after router reset
I did a reset on my RAX70 router and everything came back online except for the windows computers on WiFi. They won't connect to the WiFi at all. I get the "can't connect to this network" on every s...
- Jun 24, 2025
Thanks for the reply. I tried those but with no luck. However I did find a solution. I did another reset and then the router worked normally. Who knows why.
jstro
I also tried resetting the network adapters and so forth, though I know that's not the problem. When every Windows computer no longer connects, it's not an issue with the Windows computers.
- FURRYe38Jun 24, 2025Guru - Experienced User
Try to forget the wifi profile connection on the windows PCs.
What security mode is set on the router? WPA2 only? Try setting no security on the router as a quick test to see if any PC will connect while in the OPEN. Re-enable WPA2 after checking this.
What channels are set on the router? Try 1 and 40.
