danj77z
Jan 05, 2021Follower
Windows XP and Wifi 6?
Hello I have a RAX75 Wifi 6 router.
I'd like to get an old Windows XP computer connected to the internet. The computer sees the 2.4 ghz band fine and tries to connect, but never does. The 5 ghz band is nowhere to be seen.
Is this even possible? To connect an old, clunky computer to my new wifi 6 router?
Thanks
1 Reply
- Christian_RNETGEAR Employee Retired
Hello danj77z,
Does your old computer support WiFi 6? If not, you may need to disable WiFi 6 (aka AX WiFi) in the router's settings.
https://kb.netgear.com/000060387/How-do-I-disable-the-AX-WiFi-feature-on-my-NETGEAR-AX-router
Christian
