K0walskiK0rwa
Feb 17, 2020Aspirant
wire speed cut in half
Hey guys. my wire speed is half what i have comming to my house. I have 1 Gig from comcast and when i chceck speed from router thru QOS i have 940Mbit Download and 43 Upload. but when i chcek my...
K0walskiK0rwa
1. All firmware is up to date.
2. All disable. No positive efect. speed still the same.
3. I did enable IPv6. reboot router. No positive efect. speed is still the same.
4. did what you ask with same results as above. No positve efect. speed is still the same.
5. my 90 day pass sometime last month so nothing a can do about it now.
Topology
Feb 17, 2020Virtuoso
K0walskiK0rwa, a few comments and questions….
[1] You may be able to request a replacement router from Netgear, if the product is still within the warranty period. Please see How do I request a Return Material Authorization (RMA)?
[2] You may wish to temporarily substitute another router in place of the RAX200 for testing. If the LAN throughput problem disappears, then that is additional evidence that the RAX200 may be defective.
[3] Does the LAN throughput problem occur, when the router is in a factory reset condition (i.e., before you modify any settings)?
[4] You may wish to use a Cat 6a cable from the RAX120 to the PC, if not already in place.
[5] Finally, did this problem only recently appear – or, has it been present since you first started using the RAX200?
- K0walskiK0rwaFeb 17, 2020Aspirant
1. i already replace 1 router when i tray to fix wan agregation problem with end up with fiasco.
2. yes i will tray that in couple of day.
3. yes most of the test i did was done after facory reset.
4. i did tray multiple wire including cat 6a.
5. looks like the problem was from the beggining. i have speedtest results as far back to 10/19/2019 that show the speed never jump above 500 Mbit, unles i connect modem direc to my destop then i got full 1 Gigbit.
