Oren-123's avatar
Oren-123
WIRED AP on NETGEAR RAX20-100UK
I have purchased a NETGEAR RAX20-100UK as a one-for-one update on an existing "N" router currently acting as a wired AP on a fixed IP in a separate building (DHCP provided by ISP'S router, but local management is available on the fixed IP). Ideally, I would like to simply replace the old "N" router with the RAX20-100UK to upgrade that area to AX.
From what I've read here about NETGEAR's implementation of (wired) AP, it automatically disconnects "remote management" & turns the WAN port into an extra LAN port - presumably leaving web management only via the nominal default Web Address 10.0.0.1.
As the Web (management) address of 10.0.0.1 is not within the LAN DHCP range, I can't see that any form of local management access would be available to it.
I don't want to go for a trial run and potentially upset the current LAN to solve the configuration interactively, so suggestions as to slot the RAX20 in with fixed IP & local management on that IP would be welcome.
  • Kitsap's avatar
    Kitsap
    Jan 29, 2023
    Oren-123 wrote:
    Thanks for the help.
    Used a mix of both suggestions:
    ADVANCED > Advanced Setup > Wireless AP
    Select the Enable AP Mode check box
    "Get dynamically from the existing router. The other router on the network assigns
    an IP address to this router while it is in AP mode" - easily enough found on the ISP router's DHCP table.
    All straightforward & intuitive.  Unfortunately, the ISP Router is a Linksys Velop which is "smart" and gets in the way of allocating fixed IPs (unless you accept its help and use one it has allocated from within the DHCP range).
    As a result, I had to accept the IP it had allocated by the VELOP (which was within the DHCP range) - so couldn't transfer the N's IP to it. As the allocated (now fixed) IP was at the top of the DHCP range, I have been able to drop the DHCP allocation range down to exclude it.
    As a note - I queried the VELOP problem on their forum & have had no feedback at all, so thanks again for the help.
    Glad you got it working.  You might try to set the fixed IP of the access point on the access point itself.  It is in Advanced -> Setup -> LAN Setup.  It does not hurt anything if that IP address is within the pool of possible DHCP assignments.  Just restart the router.
    Now you have your new access point in place and your new Wi-Fi bands available.
    Suggest you mark this thread as solved.
  • plemans's avatar
    You'll literally put the RAX20 in AP mode and connect it via wan port back to your primary router.
    Its pretty easy/simple.
    Depends on how the N access point's fixed IP address is applied.  It can be applied via settings in the ISP's router and they will be tied to the MAC address of the N access point.  It can be applied via settings in the N access point's user interface or in both devices.  If you have to go back to the ISP's router, you will need the MAC address of the RAX20 for configuration.  When the fixed IP address is set, the user interface of the RAX20 should be available via that address.
    You will have to change the SSID's and passwords for the RAX20 to match the old access point.
    With a computer not connected to your LAN, you can connect to the RAX20 via Ethernet cable for configuration.  May have to search for the IP address.  Once you change the mode and IP address of the RAX20 you will have to power down both devices and reconnect to access the user interface to continue.  With the RAX20 in access mode, there is no router to assign addresses between the two devices.  You will have to set a fixed IP address on the computer in the same subnet but different address from the RAX20.  This does involve some manipulation of IP addresses and hardware settings, but it is required to seamlessly replace the N access point with the RAX20 access point.  Despite your best efforts, some of the devices connected to the old N access point may have to be reconnected by forgetting the previous connection and signing in again with the SSID and password.
    It is a challenge to do this swap seamlessly, but fully within reason.
    • Oren-123's avatar
      Oren-123
      • Kitsap's avatar
        Kitsap
        Master
