kevm
Nov 14, 2020Follower
Wired backhaul on MK63
Hello, I am brand new to this community. I jjust got the MK63 to replace an older single Nighthawk 1750 router.
The units are working pretty well in my 3 story home 2400 sf.
I want to wire the backhaul and want to determine if it should work
I am thinking of bringing the two satillites individually back to a common gigabyte switch that has the router connected to connect my wired lan
Should this work and will it be a worthwhile advantage?
Thank you
Kev
1 Reply
yes it'll work. And it should work great.
