Vinixs's avatar
Vinixs
Wired connection speed same as wireless speed
So recently i purchased a Netgear Nighthawk RAX50 AX5400 looking to improve our connection speed for multiple devices. I'm not very knowledgable with networking but I was able to get the network setu...
  • plemans's avatar
    Aug 22, 2020
    What speeds do you pay for?
    The ARRIS NVG510 is a dsl modem/router combo device.
    Do you have it running in modem only mode, the netgear placed in access point mode, or the netgear in the arris's dmz?
    otherwise you can be in a double nat.
    https://kb.netgear.com/30186/What-is-Double-NAT
    Something to keep in mind, if you're speeds are only 3mbps, most routers (even older wireless N routers) can max that speed out. You won't see a speed benefit from going to wireless AX since the router wasn't the bottleneck in speeds.
