Vinixs
Aug 21, 2020Aspirant
Wired connection speed same as wireless speed
So recently i purchased a Netgear Nighthawk RAX50 AX5400 looking to improve our connection speed for multiple devices. I'm not very knowledgable with networking but I was able to get the network setu...
- Aug 22, 2020
What speeds do you pay for?
The ARRIS NVG510 is a dsl modem/router combo device.
Do you have it running in modem only mode, the netgear placed in access point mode, or the netgear in the arris's dmz?
otherwise you can be in a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
Something to keep in mind, if you're speeds are only 3mbps, most routers (even older wireless N routers) can max that speed out. You won't see a speed benefit from going to wireless AX since the router wasn't the bottleneck in speeds.
Vinixs
Aug 22, 2020Aspirant
plemans wrote:What speeds do you pay for?
As modem only mode, I assume you're talking about doing the ip passthrough steps and turning wifi off on the NVG510. I did happen to do that and was successful getting the netgear online and on it's own network, but the speeds are just slow, and a lot slower when more devices get added. As in putting the router in AP, I attempted this earlier but the internet light went orange afterwards and it wouldn't connect. Would you happen to know anything about getting this setup correctly? I'm hoping this is the issue and not my ISP, I'm not exactly sure what speeds we're paying for since my parents purchased the service a while back. If the ISP is the issue I'll be sure to look into getting a better plan, in the mean time I'm hoping successfully putting it in AP mode works out. Thanks for the quick response!
Aug 22, 2020Guru - Experienced User
You were initially quoting a 3mbps speed. Again, it really doesn't matter how great of a router you have if your connection is only 3mbps.
that's where the bottleneck is and the max its going to get.
So check on that first. Its pointless to troubleshoot a router if its not the issue.
- VinixsAug 22, 2020Aspirant
plemans wrote:You were initially quoting a 3mbps speed. Again, it really doesn't matter how great of a router you have if your connection is only 3mbps.
Appreciate it, I'll get in touch with my service prodivder and look into getting a new plan.
