Fokash
Dec 28, 2020Aspirant
Wired connection to XR1000 slower than connection directly to modem
I have recently purchased xr1000(ax5400) and I cannot get the wired connection to the speeds that I see when connected directly to modem. I have a PC and an Xbox Series X that are connected directly ...
Christian_R
Dec 31, 2020NETGEAR Employee Retired
Hello Fokash,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
