Jin225
Dec 11, 2019Aspirant
Wired Lan Disconnects Randomly - Plug/UnPlug Ethernet at Router fixes it
On my second week with the Nighthawk AX12 Router. Have experience this issue 3 times. The Wired Lan connection to the PC through the unmanged switch (TP-LINK TL-SG1024) would disconnect randomly. ...
Christian_R
Dec 12, 2019NETGEAR Employee Retired
Hello Jin225,
Welcome to the community! This may sound silly, but have you tried switching out the ethernet cable to see if the issue persists??
I'd also like to mention that if you recently purchased the device, your device is provided with 90 days of complimentary support with our support team. You can utilize your complimentary support by registering your device using the link below.
https://www.netgear.com/support/default.aspx
Christian
Jin225
Dec 12, 2019Aspirant
Yes tried that. Have new CAT7 cables.
- plemansDec 12, 2019Guru - Experienced User
So just to get this right. you're going:
modem----RAX----switch----pc
is this correct?
What else is connected to the switch? Any of those devices having issues?
If you take the switch out of the equation and direct connect the pc to the RAX, do you still have the issues?
- Jin225Dec 12, 2019Aspirantmodem----RAX----switch----pc
That is correct.
I am unsure as to other devices that are wired in through the switch (I have 2 other Android TVs wired in did not check).
But those device that are wired in directly to the routers have IP and works.
Next time this happens I will check.- plemansDec 12, 2019Guru - Experienced User
That is correct.
Next time this happens I will check.Sounds like a plan. Whenever you're troubleshooting, its best to remove as many factors as possible that could be causing the issues. Thats why I'd said direct connect the pc to the router if possible. It makes sure the switch isn't the issue. let us know how it goes!
