Jin225
Dec 11, 2019Aspirant
Wired Lan Disconnects Randomly - Plug/UnPlug Ethernet at Router fixes it
On my second week with the Nighthawk AX12 Router. Have experience this issue 3 times. The Wired Lan connection to the PC through the unmanged switch (TP-LINK TL-SG1024) would disconnect randomly. ...
RajaDaja
Apr 02, 2020Luminary
Hello,
Did you ever figure out the cause of the LAN disconnect issue? I experienced it with the RAX80 so I returned it and purchased RAX200 Everything was fine until I did a firmware update, now it to has random LAN disconnects....no good when gaming against others. Thanks
