jwallace2121
Jun 10, 2024Aspirant
Wireless Access Point & Ethernet Hub At Same Time?
I recently purchased and quickly set up a new AX2400 Nighthawk as a wireless access point successfully. Able to connect devices wirelessly but unable to access the internet from devices connected to...
- Jun 13, 2024
Problems resolved! Unfortunately, we are not sure how but the next morning our (1) PC was able to connect to the Nighthawk AP both wirelessly and via ethernet. Guessing that our ISP router or some other setting took several hours to resolve. For the (2) laptop, we identified that a recently purchased USB-c to ethernet adapter doesn't work with our setup, but swapping it with another enabled the laptop to connect wirelessly or via ethernet.
michaelkenward
Jun 11, 2024Guru - Experienced User
jwallace2121 wrote:
I can see the hard-wired connections, but the respective devices cannot connect to the network via 'ethernet' in settings.
See the connections in what?
Connect via Ethernet settings in what?
In AP mode the router is "invisible" for most purposes. The router handles everything.
Did you find this?
What is the difference between router mode and AP mode? - NETGEAR Support
- jwallace2121Jun 13, 2024Aspirant
