tdehan
Mar 16, 2020Aspirant
Wireless Access Point
I need to replace my existing LInksys Wireless Access point. What new Netgear Wireless Access points are available and recommended for home use? Thanks!
Mar 17, 2020Guru - Experienced User
How big is your home?
Mesh network is what orbi is. Its a router and satellites that use either a wired/wireless backhaul to talk to each other and use a single ssid for all devices. It allows your devices to roam and the router/satellites to do bandsteering as needed. It allows better coverage as well as higher average throughput because of better coverage and roaming.
tdehan
Mar 17, 2020Aspirant
2500 sq ft
- plemansMar 17, 2020Guru - Experienced User
2500 sqft is the max of what I'd use a single AP for. you might see benefits from moving to a mesh network just to eliminate dead spots.
- tdehanMar 17, 2020Aspirant
We have not experienced dead spots with previous single Wireless Access Points. I'm leaning more towards the RAX200 as a replacement. I realize that it is a wireless router but I should be able to use it as a wireless access point to my existing wired network right?
yes you can. I've actual used mine as an AP before. Quite a large expense though if you're going to use as an AP.
