tdehan
Mar 16, 2020Aspirant
Wireless Access Point
I need to replace my existing LInksys Wireless Access point. What new Netgear Wireless Access points are available and recommended for home use? Thanks!
Mar 22, 2020Guru - Experienced User
What firmware do you have on the RAX?
have you tried disabling AX? AX is pretty new and not all devices have updated their firmware/drivers to work properly.
tdehan
Mar 22, 2020Aspirant
Firmware: v1.0.2.8_1.0.45
No sure about the AX question. How do I tell?
- plemansMar 22, 2020Guru - Experienced User
its under the wireless settings.
One thing I'd try first? the RAX200 had a lot of firmware changes from when it was first manufactured. If you did them all at once AFTER setup, I'd factory reset the router and try installing again. The changes were quite significant and the RAX devices have responded favorably to resets.
