cellochiqa
Jul 25, 2022Tutor
Wireless and LAN
We have a Nighthawk AX6 6-Stream AX5200 WIFI Router. The app tells me that we have speeds near 900 Mbps, but most of our devices and computers say that the internet speed is around 50-100 Mbps. The s...
cellochiqa
Jul 26, 2022Tutor
Router is RAX48, Firmware V1.0.11.112.
The router is directly connect to the modem via ethernet cable.
I am testing speeds with the nighthawk app to see what the router speeds are, and then to check wireless speeds I have been google searching "internet speed test" and using that. I tried testing it with both an ethernet cable plugged into the router and my computer and then again over wireless with similar results (67Mbps using wifi with computer less than a foot away from router, 93.7 Mbps with ethernet cable plugged into router and computer; again, we get close to 1000 Mbps service, so I am confused why the ethernet cable to my computer does not provide this). Please help me understand and how to improve my speeds.
Jul 26, 2022Guru - Experienced User
A couple things.
1. what actual model modem is it?
2. if you look under the wan port statistics, what is it showing for wan port speeds?
How do I display Internet port statistics on my Nighthawk router? | Answer | NETGEAR Support
3. Are you testing over the 2.4ghz or 5ghz? 2.4ghz is a much slower network. You can disable smart connect and name the 2 networks different so you can test each.
- cellochiqaJul 26, 2022Tutor
1. Netgear Cable Modem CM1000v2. And this is wired to the Router that says it is getting speeds of 900 Mbps.
2. I'm not sure. Is that the DOCSIS information? (It says DOCSIS 3.0 32 DS 8 US and DOCSIS 3.1 2 DS 2 US).
3. I use the 5ghz WIFI connection on my phone and computer that I am testing the speeds of.
- plemansJul 26, 2022Guru - Experienced User
Take a screen snip of the wan port statistics page. I linked to it in the prior post
- cellochiqaJul 27, 2022Tutor
I went to the website, but it isn't a secure page. Is there another secure way to find this info?
- plemansJul 27, 2022Guru - Experienced User
You're connecting at gigabit speeds.
Have you tried a simple factory reset? During the reinstall, test its speeds without changing the default configuration on it.
Factory reset is achieved using a paper clip in the little hole, yeah? For like 5-10 seconds? Not just an "unplug it and plug it back in" kind of situation, right?
