haniatassi
Oct 18, 2019Follower
Wireless speed expectations with RAX120
I am not happy with the speeds i am getting and I am thinking there is something wrong with the router. I have 1Gbps Internet and getting 900+ when teting in the router app. Over 5G, and very cl...
avtella
Oct 18, 2019Prodigy
Performance also depends on your laptops’s WiFi card and antenna layout in the laptop. What WiFi card is in the laptop? Unless you have an Intel AX200, WiFi-6 features will be useless plus don’t expect more than 10-20 max performance gain with AX with any router. AX greatest benefit is in maintaining high throughput in multi AP environments like offices and some battery saving enhancements.
Note that a standard dual antenna WiFi card available in most laptops won’t give you more than 560-600 Mbps on HT80 on WiFi AC and not more than 800 or so Mbps on HT80 AX mode (If you have Intel AX200). If you want 900+ Mbps you need to enable HT160 MODE on the router and if your WiFi card supports HT160 you will get faster speeds.
