JerBear1994
Aug 04, 2020Aspirant
Wireless Speed
I recently purchased a Netgear modem CM1150V and a Netgear wireless router RAX15. I'm getting wired download speeds of 900+ mbps, but wireless speeds of just over 100 mbps. I'm under the impression...
Aug 05, 2020Guru - Experienced User
are you connecting to the 2.4ghz network or the 5ghz network?
2.4ghz is much slower than 5ghz and more sensitive to interference.
If you're using smart connect, it might be putting your device on the 2.4ghz band and not the 5ghz.
Also, what device are you testing with? A 1x1 antenna device is going to get lower speeds than a 2x2 antenna device
- JerBear1994Aug 05, 2020Aspirant
I'm connecting to the 5g network. Testing with an app on my cell phone provides results around 70 mbps. Testing with an app on my Firestick provides results just over 100 mbps. My tv is in the other room about 15 feet away with only 1 wall in between.
- plemansAug 05, 2020Guru - Experienced User
What speed do you get over a hardwired connection on the router?
900+ mbps
- schumakuAug 05, 2020Guru - Experienced User
Wi-Fi speed depends on the capabilities of the access point and the Wi-Fi client.
JerBear1994 wrote:Testing with an app on my cell phone provides results around 70 mbps.
Make, model, version, OS of the mobile?
JerBear1994 wrote:Testing with an app on my Firestick provides results just over 100 mbps.
The Fire TV devices are purpose built to serve a specific usages, with the priority on strong video decoding with hardware decoding, reasonable good GPU, ... and not as a high speed throughput test device. Most Firestick/box/whatever calim (very vaguely) to have a "2x2 Dual-band 802.11 a/b/g/n/ac" Wi-Fi client (can't see anything about bandwidth, link ... this can translate to anything from 65 to 86 Mbit PHY link rates. Ethernet is 10/100 Mb/s where built-in, USB ports are MicroUSB so this is USB 2.0 translating again to 100 Mb/s PHY rate.
My cell phone is a Moto G6 running android version 9. I don't even use wifi on my phone really, it was just a means of testing. The primary purpose of the wireless router is for the Firestick, and occasions I have guests that need wifi. So if just over 100 mbps on the Firestick is all I should expect, that's fine. I didn't know, that's why I put it out there.
