JerBear1994
Aug 04, 2020Aspirant
Wireless Speed
I recently purchased a Netgear modem CM1150V and a Netgear wireless router RAX15. I'm getting wired download speeds of 900+ mbps, but wireless speeds of just over 100 mbps. I'm under the impression...
JerBear1994
Aug 05, 2020Aspirant
I'm connecting to the 5g network. Testing with an app on my cell phone provides results around 70 mbps. Testing with an app on my Firestick provides results just over 100 mbps. My tv is in the other room about 15 feet away with only 1 wall in between.
Aug 05, 2020Guru - Experienced User
What speed do you get over a hardwired connection on the router?
- JerBear1994Aug 05, 2020Aspirant
900+ mbps
- plemansAug 05, 2020Guru - Experienced User
So you're getting full speed to the modem and then the router.
What device are you testing speed on? (specifics)
I wouldn't test off the firestick as they're unreliable for speedtesting.
- DeMOLAY-MasonAug 13, 2020AspirantMine CM1100 wired 900mbps on RAX15 wired only 290mbps.
