JerBear1994
Aug 04, 2020Aspirant
Wireless Speed
I recently purchased a Netgear modem CM1150V and a Netgear wireless router RAX15. I'm getting wired download speeds of 900+ mbps, but wireless speeds of just over 100 mbps. I'm under the impression...
DeMOLAY-Mason
Aug 13, 2020Aspirant
Hi recently purchased a CM1100 modem and a RAX15 router. I got a 1gb plan on the modem wired im getting 900 plus mbps but on Rax15 router wired i got only 290mbps.
- schumakuAug 13, 2020Guru - Experienced User
DeMOLAY-Mason wrote:... getting 900 plus mbps but on Rax15 router wired i got only 290mbps.
Double checked this is with a correctly working Gigabit Ethernet LAN link from the test computer to the RAX15, not using a wireless link?
In case it's wireless (as per this thread subject) what wireless client are we facing here - make, model, driver version, on what operating system?
- DeMOLAY-MasonAug 14, 2020AspirantBoth wired. from cm1100 to desktop 900mbps but from cm1100 to router RAX15 wired i got only 275-290mbps
