GodsApostle
Aug 06, 2021Aspirant
WLAN errors
Getting a number of errors on my nighthawk xr500 and believe its due to problems with modem cm1200 configuration with COX Communication switch. Getting these errors every 3 seconds or more. What can ...
Aug 07, 2021Guru - Experienced User
Do you have other devices than the XR500 plugged into the CM1200?
It has 4x ports but cox only assigns 1 public IP address.
So other devices connected directly to the CM1200 won't work. (and if they do, the xr500 wouldn't work)
- GodsApostleAug 09, 2021Aspirant
No other devices are connected to the modem except the xr500 router
no other devices are connected. Port 1 is being used by xr500 router
