GodsApostle
Aug 06, 2021Aspirant
WLAN errors
Getting a number of errors on my nighthawk xr500 and believe its due to problems with modem cm1200 configuration with COX Communication switch. Getting these errors every 3 seconds or more. What can ...
Razor512
Aug 08, 2021Prodigy
An OUI loopup comes up with the vendor AboCom. Do you have an old or off-brand smart home products such as smart outlets, leak detectors, wireless IP cameras, or any device likely to be sold on sites like aliexpress?
If not, check to ensure they you do not have the same SSID as someone else in range where their smart home products may try to connect to your network.
- GodsApostleAug 09, 2021Aspirant
All known devices are identified and accounted for by ip_address and mac_address.
All unknown devices cannot be located or identified.
To my knowledge there is nothing hidden or has been left on but not connected.
I am a new resident and was not informed of any smart devices at my location but I can check to see if there is something installed.
