GodsApostle
Aug 06, 2021Aspirant
WLAN errors
Getting a number of errors on my nighthawk xr500 and believe its due to problems with modem cm1200 configuration with COX Communication switch. Getting these errors every 3 seconds or more. What can ...
Aug 07, 2021Guru - Experienced User
Do you have other devices than the XR500 plugged into the CM1200?
It has 4x ports but cox only assigns 1 public IP address.
So other devices connected directly to the CM1200 won't work. (and if they do, the xr500 wouldn't work)
GodsApostle
Aug 09, 2021Aspirant
no other devices are connected. Port 1 is being used by xr500 router
