Jaujla
Dec 21, 2020Follower
WNDR3800 Change
Hi, Can someone advise what is the correct method in copying configuration details from WNDR3800 to AX12. After I have swapped out the router can I use the WNDR as a AP? Thanks in advance.
Dec 21, 2020Guru - Experienced User
Jaujla wrote:
Hi,
Can someone advise what is the correct method in copying configuration details from WNDR3800 to AX12.-----I'd take a few screen prints or write them down. Then manually input them in.
use the WNDR as a AP?---You can. It has an access point mode.
Thanks in advance.
