Jaujla
Dec 21, 2020Follower
WNDR3800 Change
Hi, Can someone advise what is the correct method in copying configuration details from WNDR3800 to AX12. After I have swapped out the router can I use the WNDR as a AP? Thanks in advance.
michaelkenward
Dec 22, 2020Guru - Experienced User
Visit the support pages:
Support | NETGEAR
Feed in your model number, WNDR3800, and check the documentation for your hardware.
Check the section in the manual Wireless Repeating Function (WDS).
