Devilstrider
Jul 26, 2021Aspirant
Woke up to weird sound. Fragile, DDOS attack and remote access all in my AX6000 router log.
 So I picked up an RX80 used and I'm getting a lot of DDOS scans, access from remote and a little fragile. I had an R7000 previously that I also have connected to in the back area of the house. So I c...
Razor512
Aug 07, 2021Prodigy
Newer routers will flassify more types of traffic detected. Pretty much all of the DOS related stuff can be ignored unless you see the log being flooded rapidly and internet traffic performing worse than dialup.
Due to how many infected systems are out there, as well as how many bot networks are out there, they are constantly checking through every IP address in an endless loop. A common term to refer to it is internet background radiation. It is simply unwanted traffic that everyone receives because out of billions of people on earth, there are still a few million that believe a browser toolbar will give them free movies, or some app will "fix" their registry or update their drivers or boost performance.
Older routers will not add traffic to a log that the firmware never contined thhe code needed to identify the traffic.
Beyond that there are still systems online running windows XP and even windows 98 that are infected, and still trying to spread Nimda
Razor512
Aug 07, 2021Prodigy
As for any strange noises, the router would not make any beyond probably slight noises from inductors and other coils when sending data to multiple WiFi clients.
Alexa enabled devices can sometimes make noises if they encounter anything similar to the wake word, or even random combinations of noise. Since Alexa doesn't constantly transmit audio to a remote server for processing when it comes to basic commands, instead it uses a special tyle of frequency pattern recognition where it will respond to its name, but also various other sounds, including super high pitched noise. The reason is that it is not truly listening to the words, instead it is analyzing an FFT. It is also why ads can say the wake words without triggering it, by simply processing the audio with a notch filter somewhere in the 3000-6000Hz range depending on the voice saying the wake word. It distrupts the pattern enough to make it not recognize it as a wake word. Though strange things can activate the wake word. For example, if I place my alexa device too close to the HVAC system and the air conditioning comes on while during the startup sequence the hot water heater also comes on which triggers the draft inducer fan to come on, it will make the echo device think the wake word was said, even though it sounds 100% nothing like the wake word.
- DevilstriderAug 07, 2021AspirantThat's very interesting. I never thought of that
