criscris
Dec 30, 2021Follower
Won’t install
I'm getting message Nighthawked compromised by man in the middle aims to decrypt network. it won't allow my ISP to recognize either. I've turned off virus program. Same problem occurs. Help
Dec 30, 2021Guru - Experienced User
What won't install?
Whats giving you the error?
There isn't any useful information on what your setup even is or what you're even trying to install.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
