Byrnzy's avatar
Byrnzy
Follower
Jun 08, 2020
Working from home Nighthawk X6
We replaced old netgear router with a new Nighthawk X6 since the old one continued disconnected through out the day. It made it very difficult to work from home.
Is there any way to prioritize a connection so the router will not disconnect it or reset through out the day
1 Reply
  • plemans's avatar
    Which model?
    Firmware on it?
    What modem are you using?
    What speeds do you pay for?
    If its >250mbps, then qos isn't recommended.
    Is the new one resetting?
    What device is disconnecting?
    Is it connected via 2.4ghz, 5ghz, or wired?
