pdegan2814
Oct 30, 2021Tutor
WPA3 not working on 6GHz in Windows 11
I would have put the Model in the appropriate field, but it wasn't available in the selection list. I have a Nighthawk AXE11000(RAXE500) router with firmware version V1.0.7.68_2.0.35, and four PCs w...
Oct 31, 2021Guru - Experienced User
Just curious, have you tried using v22.70.x of the Intel WiFi driver?
I have a Nighthawk AXE11000(RAXE500) router with firmware version V1.0.7.68_2.0.35, and four PCs with Intel AX210 WiFi 6E adapters. Prior to Windows 11, I was using the 22.50 drivers from Intel as they allowed Windows 10 to connect to the 6GHz band using the Enhanced Open security option(I added MAC address filtering for extra security). Windows 11(and soon Windows 10 21H2) introduced Hash2Element support which is supposed to make WPA3 Personal security work on the 6GHz band. Now that all of my PCs are upgraded to Windows 11, I updated the WiFi drivers to the latest version(22.80.1.1) and tried enabling WPA3. When I do that, the PCs can't hold onto the connection for more than a couple of minutes. I can immediately reconnect, though I have to re-enter the password, and it drops again within minutes. I've since switched back to Enhanced Open, and they can once again hold a connection on the 6GHz band just fine. On the 5GHz band, they can hold a connection with WPA2 just fine. I can't use WPA3, because there is no "WPA2 + WPA3" option like on my previous Nighthawk router(I really HATE that the option to allow both was taken away), and I have some devices that have trouble connecting on that band if I enable WPA3 only.
I do not know if this is a problem with the Netgear router, the Intel WiFi adapter, or with Windows itself. I intend to contact all three support departments, and I fully expect a round robin of finger pointing. But I'm going to keep pestering until this issue is resolved. Has anyone else been experiencing something similar?
tonydi
Oct 31, 2021Luminary
Intel released 22.80.1 in early October. This driver, along with Win11, is the first time I've been able to use 6GHz with WPA3.
- FURRYe38Oct 31, 2021Guru - Experienced User
I've been using v22.70.0 on my Windows 10 PC, 6Ghz and WPA3 since August.
- pdegan2814Oct 31, 2021Tutor
How did you pull that off? Windows 10 isn't adding support for WPA3 on 6GHz until the 21H2 update comes out, which hasn't happened yet. Are you on the Insider builds?
I reported the wrong driver version. Just checked again and mines using v22.40.0. I remember someone saying there needed to be a registry modification for Windows 10 to make it work. I'll have to dig for it to find it again. I believe I did this along with the drivers installed. It's been working fine on windows 10 using WPA3 on 6Ghz.
