pdegan2814
Oct 30, 2021Tutor
WPA3 not working on 6GHz in Windows 11
I would have put the Model in the appropriate field, but it wasn't available in the selection list. I have a Nighthawk AXE11000(RAXE500) router with firmware version V1.0.7.68_2.0.35, and four PCs w...
Altsai
Nov 17, 2021NETGEAR Expert
Intel will encourage you to upgrade the OS to WIN11 which would definitely support 6GHZ WPA3-SAE and OWE mode.
DarrenM
Nov 17, 2021Sr. NETGEAR Moderator
We have a new test firmware for the RAXE500 you can find it at the link below
- FURRYe38Nov 17, 2021Guru - Experienced User
I can confirm with v1.0.1.52 and v1.0.9.72 that my Intel AX210 6Ghz PCI adapter (v22.45) install using Windows 10x64 is NOT connecting to the RAXE500 when WPA3 is enabled. I can connect the adapter to the RAXE500 if I disable WPA3 and set for OPEN security.
Same Intel AX210 adapter works on a different NG router with WPA3 enabled.
- FURRYe38Nov 18, 2021Guru - Experienced User
Adapter connected to NG non RAXE500 router using WPA3:
