wutemp's avatar
wutemp
Follower
Dec 09, 2020
WPA3 Security is non existent yet it is "supported"?
I wanted a router that included WPA3 security.  On the box it says, Supported.  On the help site it tells you where to  go to enable but the onlyy drop down is WPA-WPA2, etc. False advertising will ...
