wutemp
Dec 09, 2020Follower
WPA3 Security is non existent yet it is "supported"?
I wanted a router that included WPA3 security. On the box it says, Supported. On the help site it tells you where to go to enable but the onlyy drop down is WPA-WPA2, etc. False advertising will ...
Dec 10, 2020Guru - Experienced User
What version of the firmware are you on?
And do you have RAX40v1 or V2?
If you're on v1 and using the latest (1.0.3.88) the release notes show ofdma, wpa3, and smart connection were all pulled and if you want them to roll back the firmware a version. Maybe there was an issue found and a choice was made to pull those features until it could be fixed (which I'm sure they're working on or they wouldn't have put that notice in the release notes)
itsmehuey
Dec 10, 2020Luminary
“ if you want them to roll back the firmware a version.” quite ridiculous that they mention that because v1.0.3.80 is the only publicly released firmware with the features mentioned and they pulled this from the server due to widespread instability of the firmware causing constant dropouts
