wutemp
Dec 09, 2020Follower
WPA3 Security is non existent yet it is "supported"?
I wanted a router that included WPA3 security. On the box it says, Supported. On the help site it tells you where to go to enable but the onlyy drop down is WPA-WPA2, etc. False advertising will ...
itsmehuey
Dec 09, 2020Luminary
Netgear have completely F'ed up their AX products. They removed so many features because their firmwares have been completely unstable and un-useable, especially for the RAX40. Certain firmwares have certain functionality but others don't.. they supposedly removed them to make the router more stable.. which is a load of crap. They just released a whole bunch of version 2 of our routers (e.g. RAX40v2, RAX120v2) and I bet they're going to tell us that if we want those features, we need to buy the v2. Which is corrupt behaviour and as you said, false advertising on our products.
Newfiedrool
Dec 10, 2020Virtuoso
The RAX120 has WPA3, it lacks UL OFDMA but the V2 might just be that the old chip stocks has run low and now they are using the updated version. Both Firmwares look similar.
To be fair it's pretty good.
