fanof88
Jul 02, 2020Aspirant
WPS LED won't stop flashing on RAX80
WPS LED constantly blinking. My concern is that if that led is blinking does that mean the router is broadcasting credentials for connecting to the network for other devices to connect automatically....
Christian_R
Jul 08, 2020NETGEAR Employee Retired
Hello fanof88,
May you factory reset the router and run through the setup assistant again.
Christian
- fanof88Jul 09, 2020Aspirant
Done this and reconfigured everything and low and behold WPS light started flashing constantly again. Could this be due to netgear pushing the netgear armor security in the latest firmware update? Even though I have it disabled in the nighthawk app it still shows that it is activated. Strange that the nighthawk app settings do not line up with router login.net. THis software has some serious bugs within it. Just my opinion. Still wondering about WPS light constantly flashing. Can this be a security concern?
- Christian_RJul 10, 2020NETGEAR Employee Retired
Hi fanof88,
I'd like for our support team to look into this further. May you send me a private message with your email address, contact info, and serial number.
Thanks,
Christian
- MitchellJohnJul 21, 2020Tutor
May I ask, did you manage to resolve this Christian_R I am also experiencing the same problem.
The WLS light is constantly blinking - even after reboot and facotry reset.
I never had this problem before. The issue only started when the WLS button on the RAX80 was accidenelty pushed and from then on the WLS led won't stop flashing. It's driving my crazy.
If anyone has any sugestions I would really aprecaite it.
