ChrisKing
Sep 27, 2023Apprentice
WPS link in web interface on Nighthawk RAX70 6.6gb
Just got myself the Nighthawk AX6600 Tri-Band AX8, as an upgrade to my original Nighthawk ADSL/VDSL Modem / Cable Router I noticed in the Web Interface there is a link or tab for WPS, and whilst the...
- Sep 27, 2023
And now you know. Glad you figured it out.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Sep 27, 2023Guru - Experienced User
Can you post a picture of this web page in your next post?
Is there any WPS configuration settings on the routers web page under Advanced tab/Advanced/Wireless settings?
ChrisKing
The option or tab, is greyed out and disabled.
Photo posted which shows the firmware version, which I updated yesterday - cant click the WPS Wizard as its disabled or greyed out.
