cfleming0007
Apr 07, 2020Follower
WPS Wizard Timing out when Connecting Printer
I'm having trouble using the WPS Wizard, both the Push Button and PIN to connect my Wireless HP Photosmart C4780. Every attempt timesou when attemtping the connection. The printer is about 10 years old but I've never had a wireless issue before. Is this a compatibility issue or is there more I can do?
1 Reply
Sort By
did you try this guide?
https://support.hp.com/au-en/document/c02273853
btw, this would be your forum:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
