wonderbison's avatar
Feb 03, 2021
X6 (R8000) - AC3200 - Sporadic Wifi speeds
Hi About 3 weeks ago I guess my Wifi started being very sporadic in its speeds. Sometimes 30MB sometimes 341MB download. No settings were changed etc. Updated to latest firmware, no luck. Factory re...
  • plemans's avatar
    Feb 03, 2021
    2 things you could try.
    (try 1 then the other)
    1. try installing version 1.0.4.28 of the firmware to the R8000. Then do a factory reset and a clean install (not from backup). disable auto-updates. the newer versions integrated netgear armor and not all r8000's played nicely with it.
    2. try the virgin router in router mode and the r8000 in access point mode. Maybe its passthrough mode is sketchy
