wonderbison
Feb 03, 2021Tutor
X6 (R8000) - AC3200 - Sporadic Wifi speeds
Hi About 3 weeks ago I guess my Wifi started being very sporadic in its speeds. Sometimes 30MB sometimes 341MB download. No settings were changed etc. Updated to latest firmware, no luck. Factory re...
- Feb 03, 2021
2 things you could try.
(try 1 then the other)
1. try installing version 1.0.4.28 of the firmware to the R8000. Then do a factory reset and a clean install (not from backup). disable auto-updates. the newer versions integrated netgear armor and not all r8000's played nicely with it.
2. try the virgin router in router mode and the r8000 in access point mode. Maybe its passthrough mode is sketchy
wonderbison
Feb 03, 2021Tutor
Hi
virgin superhubs are modem router combo devices.
which specific one do you have? - I have Hub 3.0
Is it in passthrough/modem only mode? Yes it is modem only mode with DOCSIS
Standard specification compliant DOCSIS 3.0
Hardware version 10
Software version 9.1.1912.304
Thanks
Feb 03, 2021Guru - Experienced User
- astonesFeb 06, 2021Aspirant
I had a similar issue to this. Is there a fix coming in the firmware?
- wonderbisonFeb 08, 2021Tutor
Hi
I had to use option 2 route. And I am now getting the best Wifi speeds I have seen.
I will update the firmware later on and re-check but certainly option 2 seems to have been the most stable for me
Thank you
