JudyGrantham
Feb 04, 2022Follower
X7500 lites
Should blue lite glow when 5g is establishef
Feb 04, 2022Guru - Experienced User
what actual device do you have?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
