Igonzaloo
May 30, 2019Follower
XAR40 Wireless conection issues
I connected my new router with the Ethernet cable to my modem and when I try to go the internet it doesn’t work , this is the second I’m getting because the first one it said that the Ethernet cable w...
Christian_R
May 31, 2019NETGEAR Employee Retired
Hello Igonzaloo - If you recently purchased the router, I would recommend contacting our Support Team:
https://www.netgear.com/support/default.aspx
~Christian
