Donbossman
May 26, 2019Aspirant
Xbox live party issues with AX8
I created an account to hopefully get this sorted. I google searched this issue and found one topic with no solution. I can get on Xbox live just fine. The problem is when joining or creating a par...
michaelkenward
May 27, 2019Guru - Experienced User
Have you sniffed around here for stuff on the Xbox? It is a constant theme.
Search - NETGEAR Communities – Xbox live
It seems that these devices can need some careful configuration.
Hard to tell if it is an Xbox or Netgear thing. Probably some subtle interaction.
Donbossman wrote:
I’m suspecting it’s the latest firmware.
You could confirm that by rolling back to something older. Previous firmware exists on the support pages for the RAX80.
If you visit the support pages:
you can feed in the model number and find documentation and downloads for your hardware.
