staindwithink
May 15, 2020Aspirant
Xbox makes RAX80 reboot
This issue with xboxes has about driven me crazy. Both my sons xboxes and even mine, after some point during the day will make the RAX 80 reboot. It will make it reboot several times a day. I hav...
May 15, 2020Guru - Experienced User
1. What modem are you using?
2. What firmware is on the RAX80?
3. The RAX80 got several updates since its release. Since they've been such new devices, they responded very favorably to a simple factory reset and manually reinstalling them (not from backup). has this been tried?
4. Are you sure they're rebooting? Or are you getting "connected, no internet available". What makes you think its fully rebooting?
staindwithink
I was using Local NUb 1 gig Nokia modem. Now using charter spectrum modem. Still same thing. Att service never dropped. Just updated to newest software this morning. It does a complete reboot and the reason I know is because printer is connected to it also WiFi. When it drops the printer beeps so I go look at router and it’s rebooting. It ONLY does this when I have my twins for that week and they are gaming on their xboxes. When they are with their mother it never drops. Months of verification.
- plemansMay 16, 2020Guru - Experienced User
Did you do a factory reset and manual re-install after the firwmare upgrade?
