TK44
Sep 16, 2022Aspirant
Xbox Series X keeps dropping
Just bought this router and once I set everything up, I fired up the Xbox Series X and it does this thing where it'll connect via Ethernet cable for a second and then it'll disconnect. I've tried ch...
TK44
Sep 17, 2022Aspirant
no parental or access controls. IPv6 is set to auto-config
Sep 17, 2022Guru - Experienced User
tried reinstalling the firmware on it and doing a factory reset and reinstall? (don't use a backup)
- TK44Sep 17, 2022Aspirantit's brand new right out of the box
- plemansSep 17, 2022Guru - Experienced User
And sometimes where the firmware on it was several generations out of date and you go all the way to the latest, old (default) settings can cause issues. so its worth a shot.
- TK44Sep 17, 2022AspirantI have the latest firmware. I jumped from a lifetime linksys user to this and have had nothing but issues.
I'm at the of my wits eith this thingvas it now doesn't see other computers hard wired in. The app completely SUCKS can't even do advanced troubleshooting through the app. .
NETGEAR fix your systems.
